Hand-planed moldings, a short story
Pekka Huhta
19 Jul 2006
Finland
My house is built 1919 from recycled components, apparently taken from a bigger house somewhere. For my bathroom project I decided to add a few new profiles in addition to the vast amount of old recycled moldings I have scattered all over the house. Just for the fun of doing it, and perhaps to prove my dear wife that there really is a point in collecting all of those planes :D
It is pretty difficult to get good enough timber anywhere, but I had some old roof beams available (you’ll see some more on the background). Cutting the planks with a chainsaw only proved to be too slow, so I run two cuts with a circular saw on both sides of the log and did the rest with the chainsaw. Apparently the chainsaw mills are better for green wood; this stuff was too hard for a 2000W Makita.
First I made one practice piece but wasn’t happy with it. It also involved repairing a molding plane. Time and effort was lost, but it’s better to try on a small scale. Practicing is also good for finding out the proper tools: it took 14 individual planes for the first try and only 7 for the final product.
The second try was better.
A plow plane was used to reach the profile...
...and a wooden scrub to remove the excess.
A few passes more and we are close.
The curve comes with an appropriate round. I noted that although the form was OK for this plane, it was easy to smooth planing marks out with one number smaller round.
Instead of the original triple bead or reed I ended up with a double bead planed with a #45 combi.
The bottom of the molding was finished with a very small round and chamfered.
The finished test piece and the profile copied to the end of the first ”production model”. I cut a sample for the final molding in the middle of the test piece. About a foot from the end of the molding is always a bit different no matter how hard you try.
The first actual molding. I’m glad that I have two woodburning stoves in the house, I would be in trouble with all those shavings :D
For mass production I used a circular saw, thought that I had enough practice with the plow already.
As my workshop is only about 8 feet across, I had to move outside for the longer pieces. I screwed a 6” beam to my build stands and screwed the moldings to that. As the ends of the moldings are more or less useless anyway, a few screw holes don’t matter and it’s much faster than fussing with clamps.
The round went up very nicely and the final molding was just as pretty as the previous, although I had my doubts that it might look a bit different because of the change from plow plane to circular saw.
There are only a few tricks in it. First is always stock selection. If there are any knots on the stock it can be tolerated, but avoid any knots near the ends. The ends are slightly different anyway, but knots make it ultimately worse.
Another thing is to get the grain direction as tangential to the molding as possible. If the growth rings are parallel to the surface, you’ll get tearouts much more easily.
And then there is the dance. You’ll have to get your steps right in order to get the molding constant: you start from the farthest end of the molding. The force for planing comes from your feet as always, but you’ll have to take a small step back after each stroke. You can see the result from the picture below: there is a shaving sticking out on very uniform steps (except one that was cut off :)). On your way back to the farthest end you can take longer, thinner cuts to smooth the marks. It really feels like a dance after you’ve done it a couple of hours.
While I was at it, I did the moldings between the wall and the floor (another word that I don’t remember). Only an easy job with a #55.
Here they are: the pile looks ridiculously small :)
The whole process was strangely satisfying. Knowing that there aren’t that many people who would do the same, getting an idea of how it was done. And the rhythm of planing was almost hypnotizing, I bet there was some Zen involved in it :D
Pekka
Pekka,
excellant stuff. Thanks for taking the time to share.
Perhaps next time you take a video of the "moulding dance" :lol:
The moulding between wall and floor is commonly called around here a Skirting Board.
Andy
Looks like a lot of hard work, but you certainly can't argue with the results! They look great :)
Looks great Pekka and very satisfying, I'm sure. Very "green" too, in re-cycling old timbers.
Thanks for the compliments. Actually the whole job was simpler than I expected - and certainly easier than people seem to think :D
I had thought of making some longer pieces of moldings for the house, but actually one big kick for actually doing it was a thread over here about some missing 12 m of moldings. I was pretty surprised that we have plenty of neanderthals here and no-one even suggested using hand planes. I must be even earlier species than the neanderthals, would that be Homo Finnicus (that wacky Finn) then? :wink: :D
Getting the knack of it took a few afternoons, but it was only 4-5 hours to complete the moldings from 55x95 mm or 15x100 mm blanks to finalized moldings. That's about 15 m of the stuff, 3 metres per hour. So you could actually make some money with it, if the guys on the earlier post asked £300+ for the moldings :wink:
I was surprised that there was apparently no step-to-step instructions on the net for this kind of work. If everyone wants a set of hollows and rounds (well, a lot of people seem to be hunting for a set on eBay) are they just hanging idle on the wall?
Pekka
P.S: About patience... I think that knitting requires patience. Doing the same thing for hours and hours. I could not stand that for fifteen minutes. But this was fun from start to end, so no patience was required :wink:
Thats looks great, and its nice to have such an informative and interesting post. Thanks.
Adam
Smashing job, Pekka. =D> =D>
Ooo, there are - just not as many as on sharpening! :lol: There's stuff in the Old Tools archive (a particularly interesting post on doing a curved one by Don McConnell) but the best is probably Josh Clarke's shelf. Definitely follow up the link to Ken Greenburg's PDF too.
Cheers, Alf
Ken Greenburgs PDF I saw, but it's still a bit theoretical.
I'm actually glad I did not see Josh's molding :D "What makes me tick" is finding out how things are done, so it may be possible that I would have skipped making my own moldings as I already would have known how to make them :D
Pekka
Thanks much for posting the pictures of your progress.
I started trying out my hollows and rounds this past weekend and I found many more questions than answers. Your pictorial will prove to be most helpful I'm sure.
Ace
