bugbear
Pete Maddex":3qbckuct said:Go as far as you want to go is the answer, I guess.
Heresy!
BugBear
Pete Maddex":1ws0rgi7 said:I saw some pitch forks at the car boot a couple of weeks ago, maybe then are due for a come back.
phil.p":38tcylgj said:CC - For use on a shooting board, it doesn't matter much how square the sole is to the side - the iron could be offset accidentally or deliberately. Even if it's square, every time it's used it should be checked if perfection is expected.
phil.p":304n0b1r said:CC - For use on a shooting board, it doesn't matter much how square the sole is to the side - the iron could be offset accidentally or deliberately. Even if it's square, every time it's used it should be checked if perfection is expected.
bugbear":2nw0xj4m said:phil.p":2nw0xj4m said:CC - For use on a shooting board, it doesn't matter much how square the sole is to the side - the iron could be offset accidentally or deliberately. Even if it's square, every time it's used it should be checked if perfection is expected.
it's much easier to shim the workpiece than square up a plane's sides!
BugBear
