woodbloke
pre 1700?..after that date and into the 18cent, yes, but I'm really not sure about before 1700 - RobPete Maddex":armfvtb6 said:Hi, Woodbloke
I thoght they used shark skin for smoothing.
Makers prior to 1700 didn't use abrasives simply 'cos there weren't any...
Quite - there are all sorts of techniques available to us now that simply weren't practical, or even possible before. Nothing wrong with progress!Similarly, there are some jointing procedures that can't be finished straight from and edge tool...
Don't get me wrong, I'm no Luddite. I actually enjoy machining and have plenty of power tools too. The belt sander is frequently in action as I have a living to make and have to be pragmatic. Where abrasives are appropriate, I use them, but they are not an automatic choice for me, especially on repro. or restoration work.so please don't knock abrasives.
Sawyer":1duwov1f said:Makers prior to 1700 didn't use abrasives simply 'cos there weren't any...
Not quite; there is reference to the Chinese making abrasive parchment in the 13thC. Earlier still, I've heard that Theophilus mentions use of abrasive grass stems: possibly horsetail, as used by the brilliant Grinling Gibbons from c. 1670. Evidence for medieval use of abrasive techniques is inconclusive, but the possibility cannot be discounted.
Schtoo":1ojgikmm said:That curve is called 'camber' and can be very desirable. A deep camber will allow material to be planed away rapidly in a controlled manner (search for 'scrub plane'). A mild camber will allow wider, thinner shavings to be taken more easily and without tearing as the sharp corners cannot dig in and cause planing racks. A very shallow/small camber will allow very fine shavings to be taken without leaving tracks from the corners making the plane excellent for final planing and smoothing of a board.
A square edge is fine for most work too, and is essential for making the edges of boards square and true for edge to edge gluing.
Maybe the only thing I could say here is make sure the blade is sharp (always!) and try to take a lighter cut. You should not have to fight with the plane to take a shaving. I'm not saying it's not actual manual labour, but there should be no grunts, groans or curses when planing. Just a rapidly enlarging pile of curly bits of ex-board.
For now, aim for a thin shaving which will make planing easier and try to work out which way each board should be planed. Don't worry too much about anything else for now, just making shavings is enough.
Stu.
