RogerS
I have some relatively new plastic guttering on the outbuilding. The problem is that expansion/contraction with heat makes it constantly get unfixed from one particular joint. It seems to me that the fixing hoops must be acting a bit like a ratchet mechanism..in that as the gutter passes (expands?) in one direction the hoops stop it from returning back to its' original position. Over time, this movement in the same direction makes one of the joints drip.
I've thought of bolting the gutter together at this joint but reckon that I'll just shift the problem elsewhere. Overall length (including joins) is 9 metres.
Any suggestions?
Roger
Any suggestions?
Roger
