LuptonM
Mr G Rimsdale":3hy7dqyk said:Some of them come with brackets so you can turn them upside down or hold them in a bench vice. If not then it's not difficult to make something up. I've got the posh Bosch which sits upside down quite easily, but has brackets too, for horizontal and vertical mounting. That Clarke looks a big bu***er maybe more than you need, but I don't know anything about it.LuptonM":3hy7dqyk said:....
The problem with my idea is how to hold it upside down and stop it movingAbso bloody lutely! Don't buy anything!..
For a noobie, when it comes to buying equipment its like a jungle out there. Companies are always making u want something u'll never needEr - except you don't need any equipment for honing (except an oil stone). We all get taken in at some point by the sales pitches!At least I think I got my honing equipment right the first time
So how do u use your hand held belt sander to grind? Do u simply hold the plane iron free hand against the belt or did u make a toolrest to help u hold it against the force of the moving belt?
When I said honing stuff I was really refering to the float glass and sandpaper -i.e the scary sharp stuff. I thought I was going to regret it being a cheap skate and not getting waterstones but I think its probably worked out better since and I don't need/ to make a leather strop + compound as u can get the 0.3 micron paper.
However the axminster basic honing guide is pretty rubbish since the chisel holder part doesn't work and I've discovered that sometimes the guide will clamp one side of the plane iron higher that the other (which is really quite bad but I just check and correct before I hone/grind).
