Charley
Using a high speed bench grinder with a Norton 3x 46 grit stone, to grind a chisel freehand. Then proceed to demonstrate how to hone the hollow ground blade freehand on a diamond (DMT) fine grit bench stone. Any minute burr left from the process is removed (stropped) on a piece of 3/4″ MDF with some metal polish (Autosol) used as a honing compound. Finally demonstrate how sharp the blade is with some paper, the hairs on my arm and some end grain pine.
