Not used a record power planer but I'd say the quality of the Jets is....good. The castings are flat and heavy enough, and the sheetmetal body is very solid and rigid too, which is especially important if you're moving it about like I have to. The thicknessing table is rigidly supported and the fence is solid in use, if not the most sophisticated (I use a square at both ends to get it set, but realistically you don't do this very often). 3 knives is good. The cutterblock is 70mm diameter, so not the biggest. The feed speed seems perhaps a touch fast for the finest work to me, but with sharp knives it does a great job. You can disengage the feed for manual feeding, which seems a nice touch but I've not tried it in anger.
