Grinder for woodturning tools
Mike_Maple
13 Nov 2024
Leicestershire
Hi folks,
I got my second hand Charnwood lathe last year, and have been enjoying using it with the carbide chisels and some of the other chisels that came with it that were still sharp. Now however I think I need to get some sort of sharpening system set up, not to mention all those sharpening jigs! I already have my Dad's old 5 inch bench grinder, but when I dipped into this subject last year I found that most jigs are set up for a 6 inch wheel, so it's pretty useless for what I need.
Does anyone have recommendations please as to a good grinder and suitable jigs for all the usual lathe tools? Ideally not top of the range, I hear great things about Tormek(?) but I'm just starting and don't want to spend more than necessary. Likewise with the diamond wheels, I'm happy to start with the white grinding wheels and upgrade later, unless there's a good offer to begin with.
Thanks!
I also have an 8" grinder with the sorby 447 sharpening jig set, currently have the stock white stone wheel but plan to replace it with a CBN wheel eventually.
I have three old 6" TULL bench grinders. Minimum age is 35 years. I got them for free and they work perfectly. Saying that, if I had to put my hand in my pocket I would go for an 8" model. I'm used to working straight off a white wheel but if the money is there, a diamond wheel does seem like a nice luxury.
A machine dedicated to the tasks of sharpening turning tools by a manufacturer that makes both - The Sorby ProEdge. This is also a flat-platen belt grinder so doesn't make a hollow grind. The belts of many different kinds and grades of grit cost far less than grinding wheels and are quickly swapped out, unlike a wheel on a standard grinder. The machine also has a take-off on which to mount rotating buffing, polishing and other round wheels used as in a normal round-wheel grinder. It'll sharpen many other items besides turning tools.
The machine has a built-in angle setter and tool rest although there are various add-on gubbins to put on the tool rest to sharpen specialist tools in various ways. Compared to likes of a Tormek, the machine and its gubbins are far less expensive. Its also very quick and easy to make wee jigs yourself to mount on the angle-setting platform. Many British on-line WW emporiums sell this machine and its gubbins.
https://robert-sorby.co.uk/wp-content/uploads/2022/02/PROEDGE-BOOKLET-WEB-21.pdf
Round wheel grinders are often crude things needing all sorts of fettling. Most also go too fast and will easily blue an edge. People manage with them but why not get the right tool for the job? ;-)
I sold a Tormek and its gubbins 6 years ago as I was fed up with the time it took to grind anything. It was good for maintaining edges but too slow at major regrinds; and the many gubbins (one for each blade type, almost) were far too expensive. I find the ProEdge a far better machine in just about every way.
Axminster do a similar and perhaps more sophisticated version of the ProEdge but its also much more expensive:
https://www.axminstertools.com/axmi...0859?queryID=e2bb3e91c5b58d156b91a8a70586e479
