RogerS
We are having a granite worktop fitted and I've a couple of questions.
The current plan is for the fridge and freezer (each 600mm wide) to be fitted side by side. This means that the granite will span an unsupported distance of 1200mm. There is a batten at the back, the granite suppliers say it will be fine but what does the forum think? I could put an end panel in between the fridge and freezer but the end panel has a radius only on one edge and so it will look a bit naff, I reckon.
Second question - the fridge and freezer have 'plates' that screw up into a batten that fills the gap between top of fridge and underside of the worktop. I can fix the batten at either end to the two adjacent units but would people bother to fix it to the underside of the granite as well? gripfill?
Many thanks
Roger
Many thanks
Roger
