Agreed Jacob, nobody needs such a plate, if they have the ability to make something quite flat for themselves.
I have feelers, but only bought them to make my own surface plate.
It's quite evident with pivoting/hinging, tapping, and using ones eyes with good lighting, to get close, and such methods can be utilized the whole way through to unmeasurable standards for the non machinist, who doesn't have such equipment.
For planes and things, one could argue that the lapping on abrasive is more foolproof than using a deburring wheel alone, or other method of "targeted removal" (where-ever
@D_W is?)
as a high spot is obviously going to have more contact,
and the material from the centre can be removed more evenly, leaving it a simple matter of
erasing however much material one leaves on the edges
i.e how much one feathers the ink off the edge, or infact occasionally runs off the abrasive
if using a smaller area of contacted surface than the item (plane) is.
(the edges being the reference as anything the opposite is pretty much unmeasurable)
i.e if one feels the need to do the test like Cosman shows beforehand,
because after say 10 few swipes on a large abrasive would throw whatever feelers
(one thou shim stock in Cosman's case) one would be getting beyond an "Prussian blue" test if one has a permanent marker around.
One can see most of the edge disappear with one or two short strokes of the larger area,
as abrasion will favour the edges and eliminate the witness marks one has been careful to keep an eye on.
