Not as good as it used to be but picked this up from Trago yesterday bargain at £12.50
There is no reference to what the 125kg stands for in fact very little alphabetical wording just diagrammatic drawings and pics as with most packaging todaywhat does the 125kg actually refer to, is it the tension across the blade?
Thanks saved me search ,mostly will be used for cutting down bolts and screwed rod so cuts will be filed afterThis is from their listing on Amazon...'The I-125 is able to to reach over 125kg blade tension to ensure accurate cutting'
That means I got £4.79 towards another toolYou got it for a good price, it's £17.29 on Amazon. Unfortunately there are no Trago stores near me
The best blades I’ve found are the Sandvik. They also make a Sandflex which don’t break and really cut well albeit they aren’t cheap but outlast cheaper blades and perform better.Not as good as it used to be but picked this up from Trago yesterday bargain at £12.50View attachment 153507View attachment 153508View attachment 153509
are they the same quality now sandvik is bahco?The best blades I’ve found are the Sandvik. They also make a Sandflex which don’t break and really cut well albeit they aren’t cheap but outlast cheaper blades and perform better.
Good score! 🖒🖒🖒 I see that you have an Irwin blade. I've had the same blade in my hack saw for year's. Find them a great blade but haven't tried the Sandvik as others have mentioned.Not as good as it used to be but picked this up from Trago yesterday bargain at £12.50View attachment 153507View attachment 153508View attachment 153509
