Jacob
What goes around comes around.
No I haven't!Ever seen a 1200mm/4ft folding builders square, Jacob?:
My excuse is that I've always worked in old buildings, where nothing is square to start with.
No excuse for putting in new stud walls at oddbal angles, though!My excuse is that I've always worked in old buildings, where nothing is square to start with.
Used to use a long plumb rule but never got around to a plumb square, though I did have an old nicely made hardwood example kicking around in the shed. plumb rule or a plumb squareNo excuse for putting in new stud walls at oddbal angles, though!
I had to do a double-take when I saw your photo as I thought 'That's the same as mine', which it isn't, quite. Mine has no maker's name, just says 'Made in England'.well, I couldn't get a picture of the alvin, as it's see through and you can't tell that it's against the square of how large the gap.
The two aforementioned lufkin squares - I think in each case, it took me about a week in the US to wait for an auction to close at a reasonable price.
Important thing if you follow this advice is to find a relatively rust free square that shows no evidence of the rule being switched out.
The giant starrett square is a luxury to find at $25, and not something I'd buy if it were expensive (people can be pretty proud of them selling used). The blade of the square is relatively high hardness so it doesn't distort or ding easily. I think starrett would reset a square for you if you had one that needed it, but it wouldn't be $25.
When looking for combination squares, it's not necessary to find a listing that says the head is hardened, just find one with a picture of the head itself with "hardened" written on it. The listings are unreliable, anyway, as all or nearly all of the rules are hardened and sellers will type anything they can find in the heading. Lots of listings that say "hardened" with beat up unhardened heads. The corners of the hardened heads generally look nice and crisp like this one.
Having a good hardened accurate combination square for $35 isn't exactly a waste of money. If you strike a line with one of these squares and then cut to it (or set up a machine fence, etc), no part of the work you do will be wrong at the fault of the mark or setup. It was given to me by an elderly neighbour who worked on Typhoon fighters in WW2. The fact that the interchangeable heads still have 99% of their original paint suggests that maybe he didn't use it much either.
I think I spent about $6000 on steel and wood in the last year, so this kind of purchase here or there seems pretty trivial.
Many, many years ago, I did the same. I was an apprentice and was taught “make it pleasing to the eye”.No I haven't!
Doesn't work that well when you are forming new bathrooms which have to accommodate pre-cast shower trays, though! Different jobs require different standardsMany, many years ago, I did the same. I was an apprentice and was taught “make it pleasing to the eye”.
Astronomically expensive! I thought it said £9.95 which looks reasonable but it's actually £99.95!Thanks @NewbieRaf the Woodpeckers are our best selling squares, I think it's fair to say wether you choose a top of the line Woodpecker or one of our £20 Fisher squares you can be guaranteed accuracy and in the unlikely event you have any issue we will replace it without question.
https://woodworkersworkshop.co.uk/woodpeckers-carpenters-square-6/
Better price but it's an engineers square, good for setting up your fences etc. Woodworkers also need woodworkers' squares. The Woodpecker triangular shape, often called a "roofing" or "rafter" square is better for marking up but there are many more cheaper brands. I doubt there'd be many more expensive brands!
Woodpecker squares:I have a few Woodpeckers tools....all are top quality, reliable and although not cheap imports from the Far East, worth the money.
Personally, I dont see the point of cutting up sections of wood and relying on them to stay "Square" when you can buy a square that's guaranteed to stay square.
I've said it before,.....this is 2021, not 1921!!
Make your own set square.
Just spotted this on Ebay. About 12 x 7"
Nice piece of hardwood with a spline across the grain to keep it straight.
Decorative curly bits probably make it handy for holding, as well as identifying it as a thing not to be thrown away, or it could look like a random off-cut.
Hole in the end for hanging it on the wall.
I might make one for my planer fence and it'd look cool hanging on the wall!
Well yes - french curves from the good old days when everything was curvaceous!Lovely!
I'm just wondering of the decorative curly bits are actualy a curve templet.
Lovely!
Maybe it is just a template and not intended as a square.A template for the decorative bits under the treads of a cut string staircase was the first thing I thought of.
