edmund
Hello All,
Thought I'd show my first effort at turning a goblet.
http://www.filehigh.com/serve/3221/157756.jpg
It was slightly less painless than I'd anticipated, but I still have some tearout problems during the process. Had a slight problem with this on the base (hidden by the stem in the picture). More practice methinks.
As to the wobble, the problem I'm having is that once I've turned a blank cylindrical between ends, I put the piece in the chuck and cylinder doesn't rotate in a straight line on its axis. Even after I've tried to true it up it still wobbles on its axis. I'm using a Record RP4000 on a CL1 lathe. Any guidance gratefully received. Thanks, E
