Good day
As you know me, I'm a little bit "abnormal" (ok, I admit, I'm crazy).
I had to make a glue line on a few boards, but I don't have planer (jointer) so I had to make them with the router.
Usually, if the board is wide, I clamp the straight edge on the board and do it as in this post
https://www.ukworkshop.co.uk/threads/checking-diagonal-version-iv.13316/
or the improved version as in this post
https://www.ukworkshop.co.uk/threads/jointing-with-hand-router-ii.13157/
But this time, the boards were narrow so I had to find different way.
I know the "split fence" idea and I did try it but it never worked for me. I also know the "Pattern bit" idea but I don't have such a long bit (the boards are 30 mm thick). So, I came-up with this "silly person proof" idea.
I already can here the "Safety Police" shouting, "kickback" but I jointed 7 boards, each from both sides and it looks to me that the danger of kickback is the same as for ripping on the table saw or less, as long as I keep the board pressed to the fence, I don't see any problem and because of the "just shaving" cut there are no internal stresses to be released and pinch the bit.
There is one limitation, the straight edge must be long enough to cover the infeed and the outfeed, or simply, if the board is 1000 mm long. the straight edge should be 2000 mm long (for those that are "Giving up metric", 1 Yard and 2 Yards)
Later I added kind of Feather Board and it was much easier to concentrate only on the infeed.
I intend to make kind of "Feather rollers" that will hold the board pressed to the fence but not like I did for the table saw, they will press the infeed and the outfeed sides.
Pictures removed due to safety reasons
niki
niki
