Pretty much. Those lines may just be there because of the thickness of timber i normally use and the jessem guides pulling it into the fence?Are your fences straight? There are some dark lines at the ends of both fences, indicating that
these areas are seeing more friction than elsewhere.
That's an interesting approach. I think tomorrow i shall check if the fence is perfectly straight without the spacer and then go from there.it's not that at all. machines made for that very purpose can be really troublesome to set up. so some cod precision router/table/ fence set up has no chance. the stock guides are not all that either. much better to check the set up is straight using a single straight piece of stuff. then add the spacer onto that. then it must be planar.
Maybe I don't see the wood for the trees. Why use a fence with a cutter fitted with a top bearing?Do you push it against the outfeed fence? Would you use the stock guides?
Yes the cutter is aligned with the outfeed fence - as close as I can get it. Just had a thought - a top bearing cutter should make it easier to align the fence to the bearing rather than guessing where the outer most bit of the cutter is?
It's to set up the fence initially using a steel rule. After the infeed fence is set the trick is to advance a piece of wood by a few cms and plane the edge. Use your shims like a feeler gauge to set up the outfeed fence. Inevitably you won't have a shim that gives a snug fit in the gap - I use a pack of playing cards for this. I have a Jessem setup and I am sorry I didn't buy their TA fence which allows you to dial in the offset.Maybe I don't see the wood for the trees. Why use a fence with a cutter fitted with a top bearing?
I'm no expert, but that sounds to me like the infeed is not parallel to the outfeed.Pretty much. Those lines may just be there because of the thickness of timber i normally use and the jessem guides pulling it into the fence?
One thing that confuses me is that if i set the cutter so that it is not aligned with the outfeed fence, but closer to the infeed, it deosn't butt up into the edge of the outfeed like i would expect. Instead the board passes through but with a gap between the outfeed fence and the timber.
Maybe I'm just expecting too much precision!
This is the right answer.The finish for jointing offf a well set hand plane will be much better
No need to worry about the angle. Just saw/plane one board face up and the other board face down and the not-quite-right-rightangle will cancel itself out.I get a perfect ' invisible line ' joint straight off the table saw. ( a DeWalt 746 ) I set the blade to exactly 90 degrees to the table with a digital inclinometer . Not all saws are created equal but with a bit of fettling it can be done.
Thanks for your explanation - appreciated.It's to set up the fence initially using a steel rule. After the infeed fence is set the trick is to advance a piece of wood by a few cms and plane the edge. Use your shims like a feeler gauge to set up the outfeed fence. Inevitably you won't have a shim that gives a snug fit in the gap - I use a pack of playing cards for this. I have a Jessem setup and I am sorry I didn't buy their TA fence which allows you to dial in the offset.
