Brecien
Indeed! Basically the same as a spindle moulder. The two fences need to be paralell to one an other. Easily checked by holding a long straight edge to the outfeed and looking down from the top where you should see a constant gap. If not, there lays the problem; Somtimes also the farther boards could be putting too much pressure on the wrong place. Or both.I have had problems on by surface place with getting a concave of tapering cut, it's the same cut when I think about it and all about alignment of the cutting edge to the outfeed table. The way I do it in on the surface planer is adjust the outfeed table fractionally above the knives then when you try to push an edge through it will hang up on the outfeed table, I then drop the height until the work piece clears the outfeed, enabling me to get the outfeed height level with the cutting plane.
Happy routering!
