tim
I need to do some (ok a fair amount) of gilding on the library project I'm working on. The client is relaxed about not using gold leaf to keep the cost realistoc so I'm considering either gilt wax or gilt varnish. Having done a few practise pieces, I am reasonably confident about being able to do most of the detailing at a reasonable pace and keep the quality as high as I'd like. The exception is for the fluted panels which will look not dissimilar to the one below:
What I can't work out is the best way to keep a clean edge between the inside and outside of the flutes. The only idea that i've had with any possibility is to paint the panel with the base colour, mask it, rout out the flutes, apply the gilt and then remove the masking. I think it would work but I can forsee at least a couple of problems:
1. It assumes that the cutter won't lift the masking tape
2. It has to be done before fitting
There must be smarter ways so I await your advice.
Tim
![barrgrenbcdtailpil505.jpg](https://proxy.imagearchive.com/0c9/0c94aad92b480432217c76352404de9e.jpg)
Tim
