woodbloke
I've long been a fan of the Stanley 5061 marking gauge, I think its just about as good a marking gauge as you're likely to find, it sits very comfortably in the hand and the position of the pin on the diagonal makes the line gauged very easy to see. I do however, have a pair of the more traditional Axminster rosewood and brass gauges, which are pleasant enough but nowhere near as good as the 5061 (which is no longer made, I think ).....so I decided to modify the rosewood ones to make them more user friendly.
Pic one shows the gauges in question:
Pic two shows the stocks have been marked out and rounded on the disc sander:
Pic three shows a cradle machined from some iroko to hold the stem for drilling the new hole, which is a little tricky to ensure that it comes out exactly on the opposite diagonal:
Pic four shows the final finished gauges with a lick of BLO. The rubbing edge of each gauge has been rounded over and the top of the stem has been relieved so that the pin can be adjusted in the vice...each pin has been reshaped to mark as a miniature cutting gauge by grinding and then honing on a fine diamond stone.
The gauges have now improved 100% and the effort was well worth it. I don't posses a LN wheel gauge :-({|= ......yet, so I guess I'll have to slum it with the current gauges....can you mark accurately to a point tho' with a wheel gauge? A recommended and useful mod for all users of gauges ordinaire - Rob
