Garage sound proofing
flanajb
11 Mar 2009
I have a detached garage constructed of concrete block and am considering buying a combination machine in an attempt to kick start my joinery business. Initally, my plan will be to run it alongside the souless job I have in IT until the work picks up.
The concern I have is that I am always concious of not making too much noise as I know how it can annoy the neighbours and was wondering what the best way would be to sound proof the building.
My plan currently is to cladd the outer face of the garage.
Hi. Cladding the exterior is not a good move.
Build an inner studwork frame a few inches in, and totally decoupled, from the existing garage walls/Ceiling and clad with 2 layers of 15mm Platerboard with Greenglue in between the layers. Fill the cavity with cheap fibreglass insulation to deaden the cavity.
Alternativly, use Isolating clips and resiliant channel - but gets expensive. I've sound isolated a studio and a bedroom to good effect with this stuff and can testify it works if build correctly.
http://www.acousticalsurfaces.com/rsic_ ... _clips.htm
http://www.google.co.uk/search?hl=en&sa ... =&aq=f&oq=
I get the feeling the reason you suggested cladding the exterior is that you did not want to reduce an already small space. Fitting a sound resistant box within your existing garage will probably reduce your floor space by near a foot each way and reduce your head height.
That is a problem.
Good luck
Mick
I compromised and lined my single garage walls with 2" Rockwool batts, heavier than glass fibre roll or Kingspan so better sound deadening, and 11mm OSB. The ceiling had 3" Rockwool between the rafters and 6mm ply (easier to lift). So not too much space lost. This has proved to be surprisingly effective and certainly deadens things nicely. No neighbour complaints so far :)
Boz
Losing space on the inside is not really an option as the garage is not massive as it is. Would I be wasting my time putting 25mm kingspan in between the battens on the outside of the bulding before putting the cladding on ?
'Joe Shmoe's' comments above are good (I used to be in pro-audio too).
The trouble with all sorts of woodworking machines is that the noise comes mostly from cutter meeting wood - something you can't really soundproof directly. If your machine has thin metal panels AND there's room inside you can try the following strategy to help:
Get some 'Flashband' bitumen sheet-lead substitute (for roofing repairs). Stick it to the inside of the panels (outside works just as well, but it's a bit sticky and will look rather unsightly. It doesn't have to cover the panel completely, just a large-ish part of it. I use it inside computer casings to good effect, to reduce fan and hard disk noise. The idea is it damps resonances set up by motor and blade, and stops the panel acting like a drumskin.
You can go a bit further by putting Rockwool or fibreglass inside (soaks up sound), but don't expect miraculous results. Soundproofing is all about blocking small gaps and preventing transmission of sound through the structure, as well as absorbing it. Nobody wants to work in a hermetically sealed garage, especially in the summer, but door seals in particular will have a huge effect.
You don't mention the roof - if it's thin metal sheet (coil coated stuff as the cladding on DIY sheds etc.), it too will transmit sound pretty well. Old-style corrugated asbestos cement sheets will probably give the best results (tiles have gaps between them!), but if you do have a tiled roof, putting Rockwool tightly between the rafters will both improve the insulation and do a lot to deaden escaping sound (foil-faced will be best).
There's no cheap nor easy answer to this, only attention to detail.
The other thing is the PR aspect: we don't get to choose our neighbours, but you might defuse problems by explaining what you're doing, and possibly even making them something small as a present. You never know - you might end up with a commission!
HTH,
S.
Thinks - "planning" and "change of use" and "building control"
...the souless job I have in IT ...
Now that does sound familiar...
miles_hot":ycpu8iby said:
Joe Shmoe":ycpu8iby said:
I've sound isolated ... a bedroom to good effect
Oh yes... :) :p
Miles
Well someone had to say it and it may as well be me :)
Yeah it might as well! :lol:
Read my mind - at least one individual that we know had Planning come down all heavy!
You should be able to find a start-up unit on an industrial estate nearby. There is one near me in Romsey that has monthly terms and a shared meeting room /kitchen/bog if you want.
No noise problem and no planning issues and if things don't work out you have not got a long contract to cancel.
I'd be tempted to find out about such a unit, start up in the garage and the instant anyone complains about commercial activity, say you are about to move into the unit and give them details so it does not sound a hollow fob off.
Good Luck
Bob
