transatlantic
Boom!
I'm looking to add a deterant to garage door to deter would be thiefs from breaking in. It's an old up and over type door, and the garage floor has a half inch step up from the outside floor. I usually park the car right up to the door during the night, but I need something for while I'm away too.
The door itself has a lock that works, but it's still very easy to break in. I had to break in myself as I initially installed the lock on upside down :roll: , so that when I closed the door to test it, the key could only rotate clockwise, where as it needed to rotate anti-clockwise (or maybe it was the other way around). I essentially locked myself out. Yes. I'm not a smart man. Took me a while to figure it out, but all I had to do was use a thin stick to flip the mechanism at the top of the door.
So I'm looking at the locks you mount onto the floor, which would prevent the above hack. There are lots avaliable, so I'm looking for some advice. I want something that is very easy to lock and unlock as I need to do it from a wheelchair, so something I can do one handed would be great.
