Fully mitred worktop joints.
superunknown
13 Oct 2005
East Sussex, England, UK
Hi all
I have been asked to price for a worktop re-fit and the client wants fully mitred worktops....the whole joint at 45 deg.
This is not something I have done or even seen done before and not really the best of ideas imho.
Anybody else come across this before?
This practice was gaining ground as I left kitchen fitting about twenty years ago. The main advantages, I as see them, are, No jig required, Perhaps slightly less skill required as a result, Easier to accommodate a non-square corner, Quicker joint to produce, and, for some worktops, a better run of the surface pattern around the corner. There may be other reasons.
Personally I prefer a mason's mitre joint, but perhaps that is only me being pleased to see the skill of the fitter.
xy
Typical example of the customer is not always right, at the very best you would have a much longer joint :roll:
i did a mitre about 3week ago, only because it was for a counter with the postformed edge outwards
used 3 worktop bolts and colourfill adhesive and it turned out ok.
for a kitchen tho i prefer mason's mitre joint
strangely enough, I have 1 to do tomorrow, the client wants all the machinery boxed in and door on the cabinets.
Due to me using normal euro hinges
i had to make the cabs 2cm wider - duh ! :oops: but I had the doors cut to size beforehand, so now I've got 4 under size doors in white melamine. :oops:
So, need to get more mfc and try to find alternate hinges.
Any1 got some fridge door clips to spare so I can open the fascia door with the ridge door at the same time.
hs
