I do it like Paul Sellers, though I try to minimize the camber. I also use my belt grinder but I mostly use it to reset the angle and do touch ups on the hand stone. Once I get some fine trizacts I might just do it all on the grinder.
swagman":2qu041xd said:memzey; you may be able to remove the existing guards and fit a 6 inch cbn wheel; I would recommend you purchase the wider face 40mm cbn wheels; also check the rpm rating on your grinder (up to 3000 rpm on most cbn wheels);
DennisCA":1afphxh8 said:Build new guards...
I believe not, as the CBN wheels don't fracture or throw masses of hot sparks.lurker":2sulis1a said:swagman":2sulis1a said:memzey; you may be able to remove the existing guards and fit a 6 inch cbn wheel; I would recommend you purchase the wider face 40mm cbn wheels; also check the rpm rating on your grinder (up to 3000 rpm on most cbn wheels);
Sorry! but this is dangerous advice.
lurker":2cqumqv4 said:DennisCA":2cqumqv4 said:Build new guards...
Its not just a question of guards
phil.p":1shbbnmt said:I believe not, as the CBN wheels don't fracture or throw masses of hot sparks.lurker":1shbbnmt said:swagman":1shbbnmt said:memzey; you may be able to remove the existing guards and fit a 6 inch cbn wheel; I would recommend you purchase the wider face 40mm cbn wheels; also check the rpm rating on your grinder (up to 3000 rpm on most cbn wheels);
