Forum ingenuity needed
Crimping bird wire might be an idea you could use in conjunction with other ideas like pins. It's really flexible but strong.
It's plastic covered woven wire used for bird wiring systems on window ledges etc as deterrent. Problem is finding a supply that's small enough to be viable. Hmmm.
....tick tock goes the lockdown brain....
Just had a look online.
https://www.ebay.co.uk/itm/0-3-0-8mm-1- ... vh_vwMHWoQ
2mm should be right .
And crimps.
https://www.ebay.co.uk/i/303458086012?r ... %3D2386202
Might help. :D
Chris
Bob, if you wax your cramps ever few years they slide beautiful and glue won't stick to them....well white glue, don't know about polymer.
Sent from my SM-J530F using Tapatalk
I keep meaning to get some small "O" rings to slip over the end of the pins to stop them falling out when th cramp tips over, not quite got round to trying it out yet though.
Droogs":cwv5im8g said:
could you not just get some steel round bar the right size and drill and saw to length and then just make up some safety pins from gauge wire for one end and keyring loops for the other
Like this but use a hairpin instead of making one - or even 2 hairpins instead of the ring.
or those things used on the pins for quick release car bonnets.
or these?
https://www.ebay.co.uk/itm/Stainless-St ... 0005.m1851
I'm no expert but personally I'd use simple 8mm (or whatever) MS rod cut to length and make clips like those "R" clips that Droogs linked to. Easy to make with a length of piano wire from your local aeromodelling shop, and very cheap - one at each end of the rod,. or a nut at one end if you like.
