Togalosh
Hello Gents,
I've finally got round to sorting out the flaking varnish on the flooring at home & because it was not me who applied the varnish I cannot say what state the floor boards were in 13 years ago but as you can see there seems to be an issue with the wood itself not holding onto the varnish.. or is this normal? I suspect something as the main area of flaking is in front of the sofa but not by the front door or other high traffic areas & from 1 board to another it is markedly different.
I did increase the air flow under the house as we were getting a bit of damp under the stairs & in the back room _ this was advised by a professional.
These are the original 100 year old floor boards..have they just dried out too much? If so should I dampen them to get a good bond with the new varnish or is that a daft idea? What type/brand of varnish/treatment would you recommend?
Btw swmbo says no to closing up the gaps or having a new floor fitted (cah !!)
Any help or advice would be appreciated.
Togs
Togs
