Flood proofing new shed
glenfield2
2 Nov 2018
Suffolk
A year ago much of our village flooded in Storm Babet. We were 16ins in deep in he house and the garden shed at the end of our sloping site nearly 3ft under!
I want to build a replacement - it’s a shed, tool store, bike store etc. How can I mitigate flood damage. Hopefully we won’t get another Babet but who knows.
It will be a timber shed. I could raise it off the ground on ground screws maybe but realistically only 9-12 ins. I can keep vulnerable stuff hung up etc. Any thoughts on how to make the structure itself more water resistant?
Beware making it watertight will create a boat, a 4mx4m shed in 1m of water will need to weigh more than 16tonnes before it doesn’t float!
Raising off floor and storing stuff up high sound very sensible, also not using absorbing insulation or glass wool, and having the base ventilated underneath to aid drying.
The sad truth is any place that has flooded will be prone to doing it again at some time. Climate change making those floods more frequent. Site it as far up the block as you can and build it up on legs as tall as allowed. At the very least aim for the floor being above the peak of the last flood.
John
PS
This kind of thing but with the floor as high as needs be.
DIY Pole Barn Shed from Start to Finish - YouTube
The consensus seems to be to build it as high off the ground as possible,
My own workshop has flooded a few times with flash floods, and the basic observations I would make would be to keep your electrics well off the ground and have everything stored in watertight boxes , that is below waist height.
Another approach would be to build in concrete block and waterproof render it and put in a flood barrier across the doorway.
A customer of mine used to have the lower part of his garden flooded on a regular basis. He resorted to having a small, clay embankment/ polder built, which seemed to cure the problem
I’d be building it and or raising it off the ground at least as high as the 3 ft you mention. Anything that doesn’t like to be submerged in water store high as possible . You could even devise a jack system whereby it could be raised up and then lowered when conditions improve. I guess it depends on the weight of the shed and its contents ..
Incorporate a pontoon base into the design, much like you'd see in a boat marina.
Cheap and simply to make and very effective.
Two problems with getting it above flood level - permitted development height means that’ll be three feet less headroom inside.
And the missus won’t be too chuffed at having to get the lawnmower up and down a steep ramp!
Pontoon design circumnavigates both those issues.
Well it does useless some jobsworths reports the elevated ridge height mid during a flood, or the misses wants to mow the lawn during a flood.
If either of those situations present themselves, I suggest getting into the pontoon shed, slip lines and sail off over the horizon.
I hear you on permitted development but was thinking of a temporary measure rather than a permanent build during the winter months. And during any severe focast rain
Sounds like a challenge! Have you made any changes to protect the house - will they impact on the garden water levels / movement of floodwater through the garden?
Did you have time to prepare before the last storm? If you are at home a lot / work locally most of the year then that could be part of your planning.
Would it be more feasible to have grab boxes to move stuff into the house - upstairs / loft if you know a big storm is coming. Light enough to carry, sized to go through doorways and designed to stack in a corner or the bedroom or up in the loft. I would imagine you can build a big slab and incorporate removable barriers into it - but again you would have to be home to install them correctly to protect your stuff.
The obvious choice and one that will also relieve stress is to just move but I dare say selling up would not be easy. Next option is to buy an old barge and use that as a shed.
Some years ago I visited Vietnam where flooding is a regular seasonal event. The ground floor of most buildings is concrete with tiled floor and walls. After each flood they just sweep out the mud, hose things down and get on with life.
John
