woodbrains":39tcvdjw said:Hello,
What is a chip breaker?
Mike.
Paddy Roxburgh":2t72hihw said:woodbrains":2t72hihw said:Hello,
Mike.
They mean cap iron
woodbrains":2yzfb0k8 said:Indeed! I was being oblique. Perhaps we can write English instead...
NazNomad":237xkctv said:Mmmmnope, I meant chip breaker.
''Cap iron'' was used when Britain 'was' Great, but since the brexit vote we're going all 'murican now.
CStanford":3sm0kzu6 said:"...though I still prefer a fine mouth on my smoother and cottony shaving fine setting on the depth adjuster. Finishing strokes are super fine anyway on my work."
Yep. There's no need to hurry at this stage of the game, especially on projects that have been in process (not yours) for months on end, though we're likely about to be told how 'slow' and 'inefficient' this way of working is.
D_W":1sejtlsk said:CStanford":1sejtlsk said:"...though I still prefer a fine mouth on my smoother and cottony shaving fine setting on the depth adjuster. Finishing strokes are super fine anyway on my work."
Put down the wine, Charlie. The cap iron doesn't do anything for a shaving a thousandth thick, and never has been claimed to.
Then again, neither does a fine mouth - but a fine mouth does prevent a mental error of letting a plane catch on the end of a workpiece at the beginning of a stroke.
El Barto":y6wv9ttw said:Out of interest, when buying Bailey planers on eBay etc is there any way of telling if the item truly is one of the older models? I got a No. 5 planer off there a while back and it has moulded plastic handles... they reek of poor quality.
D_W":3n4enh4b said:CStanford":3n4enh4b said:"...though I still prefer a fine mouth on my smoother and cottony shaving fine setting on the depth adjuster. Finishing strokes are super fine anyway on my work."
El Barto":80ohkbhp said:Out of interest, when buying Bailey planers on eBay etc is there any way of telling if the item truly is one of the older models? I got a No. 5 planer off there a while back and it has moulded plastic handles... they reek of poor quality.
CStanford":1f7t3n29 said:I'd like to think so. I thought it was a rather productive day, all things considered.
Pete Maddex":2aovyakm said:Its something I struggle with, I find the best way is to lap the cap iron on a diamond plate resting on the blade, the thickness gives you a clearance angle and by using the blade as a base it comes out parallel to the cutting edge.
If you don't get a good fit shavings will clog the blade very fast.
NazNomad":148pvskb said:
El Barto":qqme9s24 said:Doing a bit of sharpening today and on a couple of second hand planes the chip breakers don't sit perfectly flush with the iron.
A few goes on the stone gets an improvement but still got gaps on both sides. Is it just a case of working the breaker on the stone until it's square and flat?
