Krome10
Hi all
Hope you don't mind, it's not woodwork, but I know most here are very DIY savvy and so thought I'd pick some brains for help...
I've got an old baby belfast sink I want to use and I'd like to mount it on old brackets... I've done a mock installation in another part of the house just to see how secure it feels on the brackets and I'm happy-ish with the result. If I put a lot of downward wait on the front lip of the sink, it doesn't budge. And that's using the only cr@p screws I could find in the house which were vaguely fit for purpose!
So when the time comes to fit it properly...
1. What screws would you recommend I use? Or is it simply the thicker and longer the better?
2. Is there any kind of adhesive or similar I could put between the bracket lugs and the underside of the sink? Because the sink bottom isn't totally flat, there are gaps. I thought some kind of adhesive would help fill these gaps for a better connection, whilst also giving belts and braces stability.
3. Something a plumber suggested was using sealant (something like CT1) between the side wall of the sink and the wall it will be pressed up against. Not sure how I feel about that idea though to be honest. What about you folk?
Ultimately, with decent screws and rawl plugs of the correct size and length, do you guys think these brackets would be man enough and safe for such a heavy sink? We will be using it for utility room type things, cleaning veg, etc. And I can only imagine the pain if that were to collapse onto my foot!
