Deadeye
I want to fit a CBN wheel to the grinder.
Record Power decidedly unhelpful ("you'll invalidate your warranty").
The manual said arbour 12.7mm; got bushing from Axminster (reduces from 32mm). No fit - measured again - 16mm. Assumed this must be 5/8" and me being hurried as the manual is imperial and Axminster do a 5/8" but not a 16mm.
5/8" too small - definitely 16mm.
So I'm 0.125mm too tight.
Anyone able to take .0625 off the inside radius of two bushes for me?
Or do I need to start again?
Or can I with household implements only take that off the arbour?
Grumpy.
Grumpy.
