First three boxes
frugal
29 Dec 2007
Dursley, Gloucestershire
while ago I posted the results of making my first box. In the mean time I have made another two. The first of which is the box number two from Andrew Crawford's Boxes book - a sliding lid box. The second box is a request from my wife for a box to hold matches at reenactment events so that we do need to keep cardboard match boxes around the camp.
The sliding lid box turned out okay. the new belt / disc sander from Axminster really helped getting accurate mitres for the corners, but the lid is a bit loose and is slightly off to one end when the lid is closed.
The match box was supposed to hold the long cooks matches with a recess in the lid to hold the striking strip. The dimensions were supposed to be such that it was impossible for a match head to touch the striker when the box was closed. Unfortunately I took the dimensions from the cardboard match box rather than the actual matches so they rattle around too much inside for it to be put to it's original purpose, but I am sure that we will find some use for a small wooden box at events.
The lid was attached with a strip of leather for the hinge and a simple leather clip for the clasp. I know that steel/iron pins are not ideal for oak, but they are really the only thing appropriate for a 14th century looking piece. I would have used rose head nails if I had them.
The next box is going to start after I fix the garden gate as the current one has swelled up and pushed the slats off of the bracers. (pine tongue and groove does not a good gate make)
ByronBlack":omo01y5r said:
are you a 'D&D' player per chance? (Nice job on the boxes!)
OOh very sharp eyed of you :) I had to zoom in to see that. Nice boxes too, much better than the one I've just made.
Cheers Mike
Maybe ;) After I made the box I had to find a use for it, so I stuck some of my nicer dice in it ;) I would need a much bigger box for the full collection ;)
