Yes well done indeed, it looks like Pitch Pine, did it tend to clog the sandpaper a bit and smell nicely resinous? If it is PP you did well on the finish too.
Why does everyones first attempt at things look better than my twenty first attempt?
Lovely bit of work Andy, I'm blown away by the finish for pine. 8)
The box looks well turned and finished. You also managed to get quite a good line up of the grain from lid to the bottom, which sometimes gets over looked
all I did for the finish was sand going up to 400 grit, then applied a couple coats of sanding sealer then knocked that back with fine steel wool then applied a coat of Chestnut friction polish
cheers
Andy
