whatknot":1e72kfdx said:I am glad he put on his gloves before starting work
You can't be to careful can you ;-)
Pretty sure most of the safety aspect of these machines is between the operator's ears. :-D
phil.p":1kreng6k said:Very large knotty stumps? Sounds like turnery blanks to me ...
Farmer Giles":2cza6a0n said:I got 4 IBC cages out of the "6 tonne" load of logs, so £75 per cube which going by Beau's costs sounds not a bad deal.
Farmer Giles":qzgrda5f said:The bobcat is on its limit if its a full IBC of wet logs but ok if your on the flat. I stacked the full IBCs no problem, the logs have been seasoned a little bit it rained overnight.
It does chew up soft ground but if you have hardcore and,/or scalpings it will be fine.
Farmer Giles":13pvg95x said:phil.p":13pvg95x said:Very large knotty stumps? Sounds like turnery blanks to me ...
Well, if you want to try.......
