jdeacon
I bought the plans for this bandsaw nearly a year ago. And I've had the no longer needed IKEA shelves - for the frame - for even longer.
At last, starting November 2016, I got going.
I've never had or used a bandsaw before so I have nothing to compare it against, but I ended up pretty pleased with it. It seems to have plenty of power and isn't too noisy. The star knobs and trunnions you see in the pictures were cut on it. Although both needed sanding.
Here is the big, sanity check printout:
And one shelf-worth's of individual templates:
Glueing up the first lamination of the frame. Lots of squares to, well, keep it square. And clamps and weights to keep it flat; don't want any twist to develop.
The finished frame:
Glueing up one wheel's blanks. Two cheap 15mm plywood blanks:
Pressing a bearing into a wheel flange. Baltic birch plywood:
Fitting the drive pulley to the lower wheel. Baltic birch again:
Fitting the lower wheel mount block. A hardwood/softwood "Battenberg" arrangement:
The lower mount block with shaft and wheel. The shaft is iron pipe. Couldn't find (nor afford probably) proper shafting:
Here's the upper wheel mount arrangement with tension mechanism and tilt mechanism:
A few more pictures still to come.
The finished frame:
110_bigPrint.jpg236.7 KB
120_oneBoardLayout.jpg144 KB
130_firstFrameGlueup.jpg247.4 KB
140_frame.jpg127.4 KB
150_clampingWheelBlanks.jpg248.1 KB
160_pressingInFlangeBearing.jpg227.7 KB
170_fittingDrivePulley.jpg221.5 KB
180_xlowerWheelMountBlock.jpg245.4 KB
190_topWheelMount(2).jpg211.1 KB
200_upperWheelMount.jpg205.3 KB
