Eric The Viking
- Joined
- 19 Jan 2010
- Messages
- 6,599
- Reaction score
- 76
I'm presently doing macro work with a Pentax K-series macro lens on the front of my Canon 30D.
Canon's lens mount is wider than the others (all of them, I think). This leaves enough room, just, for an adaptor to go inside the Canon mount. there are drawbacks though:
My adaptor came from eBay and was a present to me, so I can't tell you which 'shop' exactly. It wasn't expensive and it has a chip on-board to keep the camera body happy (otherwise it thinks there isn't a lens and won't work at all).
Advice:
I find my 50mm fast primes make excellent portrait lenses (effective length = 80mm). One disadvantage of APS sensors is the increase in effective depth of field. With the exception of instant review, I find digital cameras quite limiting compared to chemical (can't afford to go full frame at the moment).
Hope that helps,
E.
- The lens becomes fully manual (not even auto stop-down!)
- You lose infinity focus, because of the thickness of the lens adaptor (it's only about one millimetre, but that's enough).
- Because the adaptor is made of thin material (it has to be), mounting and removing it (it goes with the lens) is fiddly and requires care.
- Pentax chemical-era lenses have a lever sticking out at the back to stop the lens down when the shutter is pressed (so you can compose and focus at the widest aperture). Other makes have this too. You cannot use these lenses unmodified with a full-frame-sensor Canon body, as the lever fouls the mirror (and will cause damage when first attempted!). The Pentax-K lenses are fine with an APS-sized sensor though, and you can dismantle the back of the lens fairly easily and remove the offending bits, reversibly and without actual damage. I don't know enough about Minolta to know - you ought to check before trying it!
- There is potential for light leaks (something I ought to check!).
Advice:
- you stand a better chance with Canon than other makes, because of the large-diameter bayonet.
- Check on the web to see if anyone's done it with Minolta lenses.
- If there's a professional camera repairer near you, nip in and ask their advice. I'm lucky n having a good one a few streets away, who doesn't mind the occasional daft question!
- Third-party bellows units, such as the old BPM ones will let you mix mountings, for example, back bayonet Canon, front Minolta. Obviously this is only good for macro stuff, but it works well. The BPM mounting is simple, and a competent machinist, given a bayonet lens for your chosen digital body, ought to be able to make one to fit (or you might buy a cheap lens and cannibalize it).
Hope that helps,
E.
