Fiat Doblo Engine Trouble
Mark A
28 Nov 2010
South Wales
Hi everyone
We've had our 57 reg Doblo 1.3 diesel for about 6 months now and it's been fine until last night. I was driving at around 55 mph in 4th gear then felt a slight jolt and a big drop in power. It wouldn't rev past 3000, even in 2nd and 3rd and struggled to to 40mph. The engine management light came on then as well.
Strangely it improved by the time I got home, but the engine management light didn't go out. I drove it again this morning to test it and its running fine, but the light is still on.
I've done a quick google search and some people say its the turbo, while others say the injectors (hope it isn't - our Fiat Scudo was plagued by faults with the common rail, costing about £1400 in total over 2 years)
Any ideas what it could be, and what to do about it?
Thanks,
Mark
PS. FIAT = FixItAgainTomorrow - I'm very aware of that!
It could be anything to do with the engine management system, you really need to get the fault code read with a code reader.
Most cars use the standard OBD II codes these days so anyone with a code reader can do it.
They are not expensive and mine paid for itself the first time I used it by diagnosing a fault on my wife's car that the main dealer had failed to diagnose correctly and had replaced the wrong part. We claimed back the cost of this erroneous "fix" (but kept the part) and I replaced the correct part myself at a fraction of the cost. It was just the crank position sensor, not the MAF which is what they had replaced. :roll:
Some diesels suffer from faults with the exhaust gas recirculation valve. Basically these can stick open and too much exhaust is fed into the air intake. The valve is meant to be closed during starting and tickover and allowed to open once the engine is hot and running well.
One of the many cludges on a modern diesel in the name of emission control :roll:
Bob
It could be the rev limiter.
The Doblo van at the company I used to work for did this and after a lot of messing around the dealer found this was the prob, it was one of the first ones made so was a new fault to them, but I would guess but it is well known about now.
My father in law had the same problem on his Fiat Multipla and he got the part for about £ 20 and fitted it himself.
Hope this helps
Tom
Well my trusty old Fiat Ducato van is about to die! - Electrics are failing, body falling apart but it has done me well over the last ten years.
Time to start looking for a new van me thinks :( :(
Thanks everyone
I'll take the van to our local garage tomorrow. I've just went out in the van and when I set off the engine management light was off, and only came on when I went over about 3000 rpm. It stayed on till I turned the engine off at B&Q.
Driving home was fun not reving past 2500 to be on the safe side - had to coast around roundabouts then try to accelerate in 3rd. I think there is still a tailback on the A484!
Mark
PS - I know why Norm stopped making any more New Yankee Workshop episodes..... he's working in B&Q in Parc Trostre, Llanelli :norm: I did a triple-take then considered asking for an autograph!
All very well making these claims Mark! We need photos of our hero :lol:
Bob
If you have an Exhaust Gas Resurculating valve fitted (EGR) I bet you a dollar its that playing up just needs a clean. Messy job but easily done. When your engine management light comes on the car goes in to limp home mode ie cant rev past 300 revs so as to avoid damaging engine.
That makes sense. I'll read about it now
Bob
Alright. I'll try to secretly take a photo the next time I'm there. You'll see...
I was following a similar train of thought earlier Andy but as the van appears drivable up to 2000-3000 rpm This is well outside limp home type performance.
I have a 54 plate Cmax and many of those suffered with EGR valve jamming and Ford initially offered modified software that exercised the valve a few times as the engine was switched off to try and stop it jamming. Eventually they fitted newly designed valves under warranty but only to those vehicles that had a proven problem. I tried to get mine to exhibit the problem to get one of the new valves but failed. Fortunately, although well out of warranty, the valve is still working well. Good job as it is a complete ba8tard to get to - totally out of sight -only located by feel.
Bob
And it's the fact that it's a ba8tard to get to that means they weren't in a hurry to perform the replacement on all cars. I thought my s-max diesel had a sticky egr valve, as when hot sometimes it wouldnt start until the egr tube was clonked with a hammer. However, I now think it's a sticking throttle butterfly valve - the plastic butterfly expands when it gets hot, and sticks open. Clonking the throttle body frees it and away you go. (sometimes the clink on the erg tube used to free it too).
Si
What surprised me was that the Ford Duratorque engine was a joint development with Peugeot Citroen but none of French cars seemed to have similar problems with their version of the engines.
When the problems were common, I learned where the valve was and how/where to hit and carried a suitable piece of wood but thankfully I have never experienced the problem. I even tried unplugging the EGR connector which induced an EGR fault message, reconnecting it and taking it to the dealer but they were not fooled by that - bl00dy computers far too clever!
Bob
Mark
You really need to get the car plugged in to find out what the fault codes are. Until then it's like shooting with a blindfold on.
Even if the garage say it's x, y or z - I wouldn't get anything done until the fault codes have been checked. If the Engine Management Light came on - it's certainly logged the cause of it in the ECU.
Might be worth finding out what the local dealer charges for plugging in the diagnostic equipment and giving you a printout of the fault codes. Might cost an hour's labour - but could save you a lot of headaches swapping parts in and out.
HIH
Dibs
Thanks everyone
The van is booked in at our local garage on Saturday to have the fault codes read. I'll let you all know what he says when I find out
Cheers,
Mark
UPDATE:
We took the van to the garage this morning to have the fault codes read... it's either the turbo wastegate, or something wrong with the turbo itself causing it to overboost and limp-mode to kick in.
Day and a half job they reckon to fix it as all of the bits are tangled up with the rest of the unnecessary electrical systems.
I think I'll get myself a Morris Minor instead :lol:
Mark
Is it the local back street garage or the main Fiat dealer.
I had problem with my VW transporter earlier in the year and the local garage said it was a couple of days work to fix, but the VW garage said it was 3 hours and saved me a boat load of money.
If it is not the main dealer I would get a price just in case they are cheaper overall.
Some times they know things your local garage may not.
Tom
mark aspin":13dl9lgd said:
UPDATE:
There may be a valve (electrical\vacuum) that controls the turbo - there certainly is on all VAG cars. If this starts to fail - then the car will go into limp mode and someone who isn't familiar with them would just suspect that there is an issue with either the turbo or its wastegate - when in reality it's a readily replaceable valve, with a few vaccum connections and a electrical multiplug.
Is the local garage a Fiat specialist or just general type place?
Do you know what the fault codes were?
Dibs
