I currently have a 110 volt corded Bosch GST135BCE jigsaw but maybe tempted by
The Bosch is ok for thin materials, probably why it is called a jigsaw but with materials around 20mm it can be hit and miss as to squareness but over 30mm the cuts are often not square and I have tried various blades from different manufacturers and it makes very little difference. Some of the better results are achieved with the Bosch T1044 Dp blades that have about 200mm of teeth or the shorter T744 D. But I have been looking at other jigsaws and various reviews and it is the Mafell P1CC that seems to stand out, it was the most expensive jigsaw ever but in a class of it's own along with £40 blades ! So is this jigsaw at £400 really that good to warrant it's price tag ?
The almost as expensive Festool PS 420 EBQ-Plus is a mere £395 https://www.axminstertools.com/festool-ps-420-ebq-plus-jigsaw-body-grip-230v230v-503679 but still retains a blade guide system whereas the Mafell has no blade guides but cost £408 https://www.toucantools.co.uk/mafell_jigsaw_p1cc_maximax_110v_in_t-max_systainer.html.
Who owns a Mafell and is it as good as the reviews would have you believe or is it a case of having spent that amount of money you convince yourself it is that good !
I cannot see how the Mafell without a blade guide can deliver better results than other jigsaws with a blade guide unless it is fitted with the thicker Cunex blades, I would have thought that using standard blades without support then the wander would be worse so any Mafell owners out there who can give some feedback please.
