@TRITON, I have what I think is a well equipped wood shop, complete with a Minimax SC2C sliding saw, but wanted to use the TS 55 tracksaw for this project. All pieces were easily cut in one day from full sheets, and the longest delay to get to this point was waiting for the two coats of undercoat and two coats of paint to dry.
All of the plywood and MDF for the three-bay basement sink cabinet were cut with the TS 55, TSO parallel rails, TSO rail square, Domino DF 500, OF 1010 router, PS 300 jigsaw, ETS EC 150 ROS, and KS 120 miter saw. I'm still waiting on the Blum hinges so I can attach the doors, but finished the plumbing for the water and lift pump on Wednesday. The sewage drain in my mostly below grade basement is a meter higher than the bottom of the sink, so I needed the pump. I still have to attach the splash guard on the countertop where it meets the wall and attach the edge banding on the ends of the countertop, but the sink if fully functional and I now have running hot and cold water in the basement.
I ripped the full sheets of plywood and MDF in my garage so I could carry them to the basement by myself. Each of the three cabinet carcass is 18mm plywood, the drawer sides and ends are 12mm plywood, the drawer bottoms are 6mm plywood, the two cabinet bottoms are 12mm plywood, and the drawer faces and doors are 18mm MDF. I had the full sheet of MDF for another project; otherwise, I would have used 15mm MDF.
The drawer sides and ends are 98mm tall, and it was easy to set up the parallel guides on the FS 3000/2 rail for repeated cuts until I had all of the 2500mm long strips to take to the mitersaw. Likewise, the drawer faces, and the false front in the sink bay were 126mm wide MDF strips that were cut to length on the mitersaw. The eight bay side panels were the easiest to cut using the parallel guides and the rail square on the FS 1400/2 rail.
I was tempted to use SC2C or the DashBoard and fixed fence setup on my MFT-style worktable to cut the sheets and the router table to round over the drawer faces and doors, but this was a proof of concept project to see if I could make cabinets with what I could easily haul in my truck. Aside from the FS 3000/2 rail, the tools I used would easily fit in my truck, with most of them in the cabin. The CTL 26E vacuum, with attached Dust Deputy cyclone, would be in the bed of the truck with the pair of FS 1400/2 rails I would use instead of the FS 3000/2.
