I'm looking to rationalise the dust extraction in my workshop. I'll continue to use my ADE 1200 for the planer thicknesser and a few other other similar machines but need to do something about the smaller power tools.
I have an Numatic NV750 which I want to use with my Kapex, TS55, Domino and a host of other hand power tools, mainly from Dewalt. I also want to attach something to the fence of my router table - a shop built unit.
Rather than having several vacuums I was wondering about taking Peter Parfitt's approach along the lines of the Dust hub. Link here: (1) How to make the workshop Dust Hub - YouTube
My thought is to route the 50mm outlet available on the NV750 into the hub and to have a number of outlets: one to Kapex, one to my assembly bench, one to the router table and one as a general purpose 27mm hose which I can connect to miscellaneous power tools and to the Henry vacuum tools.
I'm thinking 36mm Festool hoses, probably not the antistatic ones (on grounds of cost) to the Kapex and the assembly table and a 36/27mm reducer at the assembly table for the smaller inlet tools. I need to think a little more about the connection to the router.
I'm wondering about buying a 7 metre length, cutting it down and adding in a number of additional inlets and outlets to connect to the various lines.
As we all know, Festool stuff isn't cheap and I don't want to spend a load of money and find that it doesn't work well.
So, firstly, are there any obvious issues that you can see with this idea?
Secondly, can anybody comment as to how well (or otherwise), the Festool connectors fit on the Axminster 63mm blast gates?
Finally, if I have 36mm outlets as well as 27mm ones on the assembly bench (by way of the Festool 36/27mm adapter) , are they flexible enough to attach safely and efficiently to most of the other non Festool tools out there, I'm thinking about my DW 625E, the DCW210 amongst other things?
I appreciate that its possible to add additional reducers but this puts the cost up even more and could make it harder to manipulate the tools around on the bench.
The more I read on the web, the more confusing it all becomes. I'm looking for people who have done something like this and who can offer advice.
thanks
thanks
