PJBuzz
https://www.aldi.co.uk/ferrex-bandsaw/p/810249541009800
Whatever project you're working on next, make sure you have the right tools to get the job done. With 2 cutting speeds this Ferrex Bandsaw enables smooth and precise cuts in both hard and soft wood up to 120mm thick. The solid, all-steel machine has a powerful yet quiet motor, quick lock for fast and rigid locking, and long ripping fence for accurate straight cuts, so you can be sure you'll get the results you're after. The table is solid and sturdy, and is even adjustable from 0° to 45°, allowing you that extra bit of freedom as you work.
Features
3 Years
![Ferrex-Bandsaw-A.jpg Ferrex-Bandsaw-A.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/108/108527-Ferrex-Bandsaw-A.jpg)
Features
- Multiple cutting speeds
- Cuts wood up to 12cm (approx.)
- Electro motor
- Solid die-cast alloy tiltable table
- Quiet but powerful
- Long ripping fence
- Quick & rigid lock
- Solid all steel construction
3 Years
