you're right it is a brilliant bit of kit.
i have had one for about two years, it only gets used when i'm in a hole but then i am always amazed by what it can do. the only problem with the older one was the way some of the blades moved. that has now been addressed with the star washer attachment and the new blades.
for me though the real thing is the way it sands in the smallest spaces.
who'd have thought such a small motion could deliver such good results?
(did i really say that sounds very sexist!! :lol: :lol: )
also apparently the new bi metal blade also works well on metals so should be good for older floor boards. the only problem with all these tools is getting into the very tight corners. you have to keep moving the blade around the spindle to get to the edges.
it will get warm, but seems to go on for ever. german engineering again????? :lol:
ages ago i bought one of those mini trim saws that was supposed to cut tight to the wall for laminate etc,
but, because of its design, you lose about 12 inches on the right hand side.
its that mauve machine you see on QVC. sometimes you wonder whether designers ever use their brains???
whilst i have not yet tried all the tricks in the fein brochure, it so far has done everything i have asked it to do.
paul :wink:
