February's Competition Project Discussion
Pvt_Ryan":2cfjc1xi said:
@Blister, Does the hole at the top for the candle need to be drilled for the comp?
I am holding off doing that until I get a metal thingy and see what size it is.
Hi Ryan
Rules are :-
Candlestick to be a minimum of 20cm 8” tall and a maximum of 41cm 16” tall
( Excluding the candle )
I had hoped people would show the candle stick with a candle in the top , I will be :mrgreen:
I have been having trouble getting a shape of candle I like (bistro type) None of my local shops stock them, only tapered. eBay to the rescue.
Do you need the metal things? I didn't bother for the comp. I know you need them if you plan to sell um.
What do you call a candle stick without a candle in it :?:
... A stick
rules is rules :D :D :D February's competition is for a Candle Stick
.... You can be so wise when someone tells you the answer :lol: 8) :lol: .....
:oops: :oops: :oops: :oops: :oops: :oops:
Thanks Blister - had you not said I wouldn't have put a candle in mine
Hi Blister,
Can I assume we can be a bit flexible on the picture size this month? Strangely, for a candlestick, mine is rather taller than it is wide. So the dimensions of my pictures are not exactly over square. I will try and make it 640ish high - OK?
gus3049":2bx88c2g said:
Hi Blister,
Hi Gordon
The reason for the file sizes and 3 photos is as follows
1 To keep the file sizes small x 3 = lower band width use for the forum , it all costs money and we get the use of the forum for free
2 To keep all entrants image sizes the same , A level platform . No advantage of Big file sizes / photoshop etc
This months requirements for photos are :-
Please post 3 images of your work
1 side profile
2 others showing close up details you want the judge to see
Image size please use image size 640 x 480 0.3 mp, same as January
Please keep to this
Allen
Blister":3njm21s2 said:
gus3049":3njm21s2 said:
Hi Blister,
Hi Gordon
1 side profile
Please keep to this
Allen
OK, but if the tall dimension is 640 the smaller one will save more space!! I'll add a border!!!
gus3049":3fhsrgzk said:
Hi Blister,
Hi Gordon
1 side profile
Please keep to this
Allen
:) Surely 640 x 480 is the same as 480 x 640, just turn the camera 90 deg ?!?!? :shock:
:) Surely 640 x 480 is the same as 480 x 640, just turn the camera 90 deg ?!?!? :shock:[/quote]
Yes indeed, but I'd cropped the pics to get rid of the background that was intrusive!! Can't do them again because the candlestick has already gone to the art gallery!! No probs, I've just added some white space!!
As discussed last month, my camera doesn't do the prescribed dimensions.
I just take the pictures post them in Photobucket and click the resize option to the specified 640 x 480, which was agreed as being fine.
The link then has a suitably sized picture (unless I am told otherwise...) Problem solved.
Now I just worry about poking the spinny thing with the appropriate bars of metal
Completed entry's ( 3 photos ) to be uploaded after midnight on the 22nd Feb. up until 10pm on the 24th Feb, after this time the forum thread will be locked for Judging.
4 DAYS REMAINING
Results will be posted up on the 28th
I know I'm cutting it fine...(as I did last month) but did so many leave it till this late last month to turn their entry? Should we be concerned?
