Taffy Turner
At the risk of poking my nose in here, I think that Jacob does have a point, but I would question his way of getting it across!
Gary
Gary
You have a point, though I think it's worth pointing out that, in my own case, I was unable to fettle cheaper brands and even sharpen properly until I had used an LV plane mainly because I had no idea of what an acceptable standard was. Without a reference point I found it difficult to know whether I had set tools up to their maximum capability or sharpness. Trial and error or a course might well have been a shortcut but using a higher end tool that was "preprepared" to some extent was a great help.Mr_Grimsdale":5she90u6 said:I get tired of the often repeated message that only LN, LV are any good and everything else is rubbish. It's not true and a lot of people esp newbies are being misled.
Mr_Grimsdale":v8s6poyq said:I get tired of the often repeated message that only LN, LV are any good and everything else is rubbish. It's not true and a lot of people esp newbies are being misled.
I'm sure they'll be OK but the trad 'pig sticker' pattern is far superior. See earlier thread somewhere.Ian Dalziel":27om9j52 said:Jacob,
Newbies ask for opinions here on certain tools....whats best to buy for the money…they get answers more often than not ‘buy LN or LV’ because they work very well out the box. Others don’t…they need a fair bit of work to get them to function the way a plane should work….. Some newbies don’t have the yet aquired skills to make them functional…this comes with eventual experience.
hence all the recommendations.
I’ve just spent £229 on the LN mortice chisel set……you’ve repeatedly said in this post they are bad….you now have me concerned. I take it with your set you are really disappointed with them….in a case like yours LN would probably replace them if you are not entirely satisfied.
Just wondering what your concerns are…..are they not flat….or suitable for the job…have you broken a handle, please enlighten me as I am looking forward to using mine and I want to know if mine have the same problems as yours.
I
Well I've never knowingly fettled any of my hand tools ancient or modern - I sharpen them, use them, occasionally apply candle wax, er, thats it. The flat back thing comes about inevitably as the blade is turned over flat to take off the honing wire edge burr wossit called.Tony":3fzo2q3u said:snip
Jacob, you don't see the point of LN or LV tools. Well, I used my fettled Record #4 at the weekend and then my LN LA smoother (same size more-or-less) - I clearly see the point.
I am surprised that this community has produced such a thread; it is beginning to match the disgusting, almost racist, witch hunts offered on WC
Have used pig stickers (old ones, no brand) extensively. Have also used modern pattern not unlike LN type (actually Marples). I'm just expressing a preference for a design. IME the first are much superior - the reasons why are expanded in an earlier thread if you search.Ian Dalziel":2xu9p6b9 said:I'm sure they'll be OK but the trad 'pig sticker' pattern is far superior. See earlier thread somewhere.
possibly so......but at the very least try them before you publicly condemn them to being useless.
I
Perhaps less finger waving and more stopping to think why, on a forum where name-calling is very much the exception, you've apparently drawn quite so much. For me, the last straw was Philly asking you to make your point in italics. Philly is, as a rule, so laid back as to be horizontal and this is the equivalent of me having a prolonged rant. When you start making him visibly irritated it's time to stop. The mild ones are always worst when they're riled... 8-[Mr_Grimsdale":lmzo87kc said:My response is 2 fingers. I'm waving them now!
I haven't read any bad language, or indeed anything that could be taken as offensive.
I just looked back through this thread and for having a different opinion I have been called; a troll, holder of bizarre views, green-eyed monster, tedious nerk, jealous twit, Nay-sayer, narrow-minded, racist, witch hunter!!!
Mike.C":sddj8erl said:from Axminster (he did didn't he?)
EDIT Sorry Tony I did not see your post
David C":2re1blyf said:Steady on chaps!
Not quite as hot as WC yet but getting close.
I find the deliberate attempts to wind up other members by the use of infantile/childish sarcasm, highly questionable.
Respect for others regardless of the oddity of their views, (if stated reasonably)?
David C
