Duiker
Tony,
Is your guard along similar lines to my strip of MDF held on by clamps?
Mick
Mick
No problem for the integrated measuring system.You can have it for free.houtslager":32ap305q said:all the best Chippy !
btw - will dino give the integrated measuring upgrade to present users for FREE ?
Jake":30r5arpu said:Perhaps someone could pause from their salesmanship to comment on whether or not the system leaves part of the saw blade unguarded, as it looks from the pictures?
ez dino":32zhxukt said:If you see other edge guide 'systems', they give you a flat base with no opening for the guard. The Smart base is the first base that allows the guard to operate.
very good point.johnelliott":26j9kjbo said:ez dino":26j9kjbo said:If you see other edge guide 'systems', they give you a flat base with no opening for the guard. The Smart base is the first base that allows the guard to operate.
Festool saws don't have guards because they are plunge saws. As soon as the operator stops pushing down the blade is retracted into the body of the machine.
Hi Timtim":2yvirgol said:Does the Festool saw have zero breakout when loose ie not in the guide rail?
Duiker":drxwlwuu said:Tony,
Mick
Tim.tim":1oio411i said:I know this thread is about the EZ system but since there is comparison to the Festool system I hope its okay to ask a Festool question>
Also (and this might seem nuts but i'm thinking about the router possibilities for the EZ system as well here) can you use the Festool plunge saw in the EZ system?
Tim
Aragorn":1ekjoz5y said:So... Not even making a stab at my spot the difference competition, then, eh
Aragorn":152c7uy3 said:Tim
The festool depth of cut is 55mm, reduced to 48mm if using the guide.
So... Not even making a stab at my spot the difference competition, then, eh :wink: [-X
Aragorn":dzswpnjx said:Well, Tim, I don't know how you did it, but you're right. Left is without the guide
Dino":dzswpnjx said:If you look at the EZ as a competition, that's what you have.
But if you look how to gain from it, that's what you get.
Anyway, the choice is yours.
tim":39h60vzn said:Dino - this could be the old adage of two countries separated by a common language.
I said 'as competition' not 'as a competition' . It clearly is a reasonable competitor for my money with the Festool system. I'm just trying to get some more info on both systems before i make the call to buy one or the other.
Tim
