Joe90
Sorry to be dragging up this old thread...
I am having the exact same problems with Cascamite (extramite).. the instructions say 3.5 times the powder to 1 times water by volume.. however when I used 7 coke bottle lids of powder to 2 lids of water there is simply not enough water to dissolve the powder!!! :shock:
(The instructions say two parts powder to one part water by weight, 3.5 : 1 by volume)
So I cancelled the glue up and used the mixed stuff to glue some samples.. I will test for strength tomorrow... in the end I had to go with about 7 lids of powder to 4 or 5 lids of water to get a paste rather than a clumpy mess.. this is far more water than advised...
Is this a problem? Does out of date Cascamite behave in this way?
One poster mentioned that you have to mix for a long time with seemingly nothing happening, then all of a sudden it mixes ok... so i will try this.
I tried ringing the phone number on the tub but got a 'no such number' tone, can't find any other contact details.
I have seen several web pages that say two parts water to one part powder, presumabley by volume.. this would mix ok I'm sure , but is totally different to instructions...
Ok, I did use a paper cup, my bad... will use plastic or glass next time...
http://www.eccabinets.com/ExternallyLin ... clumpy.jpg
http://www.eccabinets.com/ExternallyLin ... 2water.jpg
Finally, will normal wood glue join two MDF pieces face to face in a long lasting and durable way? (It is to fake thickness by adding a lower rim around the perimeter of a table top)
Joe
Joe
