For instance a 1.5 hp dust collector that can move a maximum of 1100 CFM moves far less air than that maximum depending upon what sized ducting we use. This typical small shop dust collector blower only generates 4" to 6" of pressure when working. With the added overhead of our filter and minimum ducting, that pressure is only ample to move about 800 CFM when hooked up with a short piece of 6” flex hose. That pressure will only pull about 550 CFM when connected with 5” flex hose and only about 450 CFM when hooked up with 4" flex hose.
Whether you have a modest 1/2 HP 600 CFM blower to a roaring 5 HP maximum 2300 CFM blower you need to balance the ducting size. We constantly trade off our ducting size to move the right air volume at ample speed with minimum resistance. To get the needed 800 CFM that larger tools need for good fine dust collection through a 4" duct or hose you need about 9,000 FPM that takes a monster impeller and huge motor. That's why knowledgeable woodworkers use 6" ducts and 6" flex right to their larger machines even with portable dust collectors. Without a monster blower, if your duct is smaller than 6" to your larger machines, then it will not move enough air to capture the fine, most unhealthy dust. The best you can hope to do is make your system a little more efficient.
