Due to all the snow and sub-zero temperatures lately, I haven't been able to spend more than a couple of every hours in a single day working on this table.
I've spent too much time messing around with these poorly placed biscuit slots. I tried re-cutting the slots and fitting biscuits in there (twice, in fact) but, each time I came to plane them flush, they literally fell apart (the PVA doesn't hold too well in this weather, either). :x Yesterday, I decided I would at least
try and do a proper repair...
I resawed some scraps of beech on the bandsaw (fortunately, I keep forgetting to offer my offcuts boxes on Freecycle! :wink
and painstakingly hand-planed and sanded them down to size. The grain match is fair from perfect but, they do look better than the old biscuits and, well, at least I tried.
It really has been cold out there, lately. Several days before the snow hit on Wednesday, I found this tin of water had frozen :shock: - it's only on the surface but, I've never known it to be that cold in my workshop before.
Also, where my roof leaks (melting ice and frost) and inevitably drips on to whatever it is I am working on, I found this frozen lump, one morning.
Shovelling snow and breaking ice to try and clear part of the drive warmed me up this morning so, I braved the conditions of my workshop to try and finish shaping the top.
Here's one tip for you - I pinned a thin length of beech to two scrap blocks. When clamped to the existing curve of the outer leaves, I could clamp this to my top and use it as a guide to draw the perfect curve. Don't know where I got this idea from though, I'd like to think of it as my own... :wink:
I did have to spend some time 'fettling' the fit between the two leaves, as I made one edge a little
too concave. Lots of awkward work fiddling with a spokeshave at either end, because of all the wooden keys (they also needed reducing in thickness a little bit).
My 12in. disc sander really wasn't up to sanding all that end-grain so, I had to think like a former-cricketer
and came up with this...
It worked quite well. In fact, there's an additional tip for you, here, which I picked up from watching a video on the Australian
Walko Workbench (it's basically the
ultimate Workmate!). I can't believe I never thought of it before but, if you remove the 'fixed' heads on a quick-grip clamp, the bars will just about fit through a 19mm dog hole! 8)
I used to have a purpose made MDF jig for holding my belt sander in this position. This next shot shows why I should never have chopped it up, only two-months ago...!
For my last tip this evening, a little inspiration from New Yankee Norm to try and hide those horrible splits on the underside (this was on the very first episode of the New Yankee Workshop, as highlighted in a recent thread in the General Woodworking forum).
I'm almost ready for finishing (worktop oil) but, the weather is against us woodworkers, at the minute. Assuming my mum can get to work on Monday and Tuesday, I might have to take my workshop in to the kitchen!! :twisted:
