I always drill at least 10 mm deeper than needed (more if theres the depth available) then keep the drill spinning as I pull and push the bit a few times, this pulls the majority of the dust out, and the remainder falls into the bottom of the hole..
El Barto":lpl4kwud said:Using epoxy to fix bolts/threaded bar into brick is also a handy solution.
That's the theory! In practice, for me anyway, I hammer the sleeve in first and then screw in the metal bit. Hammering the whole thing often makes the metal part slide too far into the sleeve too early in the process.Chris152":dcz2wlui said:According to this link, you hammer rather than screw them in?Woody2Shoes":dcz2wlui said:I agree about the frame fixings - most of them are relatively thin, and pullout strength increases markedly as the diameter of a fixing goes up, all things being equal - also I quite often shear the head off as I do them up.
https://www.youtube.com/watch?v=8NIUfORnK8g (about 4'40" in)
Why not do them at 400 or 450 spacing - actual figure not really important here - but accurate/regular spacing looks good if the end results will be visible.Chris152":36s04c9v said:Yes, Lons put me straight on that one W2S, it was me getting confused.
Speaking of which, I wrote that the piece of wood running above the windows was 2.6m, it's actually 3.6m. Should I aim for more than the 5 screws I originally intended? Maybe 7?
Delivery was due yesterday and they've still not arrived. With nowt else to be getting on with I'm like a child on their birthday, sat looking out of the window waiting for the postie to arrive.
I'll do that - the cross pieces will be at approx 46cm spaces so I'll do the same for the fixings. Thanks!Woody2Shoes":2kxujz3j said:Why not do them at 400 or 450 spacing - actual figure not really important here - but accurate/regular spacing looks good if the end results will be visible.
sunnybob":1uiuttd2 said:Modern masonry bits are usually made of chineseium. :roll: I've just installed 10 mm thick ceramic tiles in a bathroom and averaged barely a couple holes per drill bit. .
Chris152":1vc131e2 said:I've no doubt it looks to most of you like it's waiting for the next thing to be done, but that's it!........
