Phil Pascoe
Try not to get shot at so often?
Just revisiting the above - were we given a marking knife too, with our end of course Carpentry & Joinery course kit? Checked the list - answer is no.Jacob":27tx0kj1 said:Just a detail but I see "marking knife" mentioned.
This causes a lot of confusion because knives are not used for marking, but may be used to cut a mark already made, where a clean cut edge is essential. It's a misnomer.
Mark with pencils, you can rub them out if they are wrong. Or a scribe point sometimes if you are confident about getting them right. Trying to do it with a knife is a PITA.
There is an exception - I've seen old work marked with a knife on just one of the four sides and my theory is that the foreman would have done this from the rod to avoid mistakes, an indelible mark to be completed in pencil by the bench hand.
Also nobody needs "dovetail markers" whatever they are. They were always done freehand, which is not that difficult. If you wanted absolute perfection you might mark out with dividers and a sliding bevel, at the angle of your choice!
As you've mentioned Jacob, that's a great list for a carpentry & joinery tool kit, but the OP required cabinet making tools. Many on your list would pass muster, many should be kicked into the long grass as in my book, they're not suitable for cabinet work. Namely, firmer chisels, nail pullers, most certainly a boxwood rule (not nearly accurate enough>parallax error) carpenters axe (!!!) spirit level and plumb bobJacob":z6v71n5q said:Just revisiting the above - were we given a marking knife too, with our end of course Carpentry & Joinery course kit? Checked the list - answer is no.Jacob":z6v71n5q said:Just a detail but I see "marking knife" mentioned.
I've got two now but I never use them and can't remember where they came from
Tops course kit
1 toolbox - made week 5
5 1/2 Record jack plane
Good quality Sanderson & Kayser saws:
26" hand saw 6tpi
22" panel saw 10tpi
14" tenon saw 14tpi
3 Marples firmer chisels 1" 3/4" 1/2"
Rabone Combination square
Whitehill 16oz claw hammer
Nail pullers (Footprint?)
sliding bevel (poor quality)
double sided oil stone - box made week 6
big screwdriver
small screwdriver
2 ft boxwood rule
nail punch
brace & bit (one 32mm bit for yale locks
mallet
S&J carpenters axe
marking gauge
bradawl
brass face marples spirit level
plumb bob
woodbloke66":29wmw8aj said:......I'd agree that a sharp 4H pencil is also pretty good.......
Firmer chisels are No1 for chopping out DT sockets and similar. They are the workhorse and a good range of sizes is useful. Bevel edged just for finishing, getting into corners, etc. You only need 1 or 2. Cabinet makers (working by hand) would also need mortice chisels.woodbloke66":ro2z2c88 said:.......
The marking knife(s) need to stay, but I'd agree that a sharp 4H pencil is also pretty good and I use both extensively - Rob
MikeG.":33ixzhwj said:I've seen metal workers and engineers mark steel with a white pencil. Would that suit wood? If so, what are they called?
Trevanion":19v7gvj5 said:......It's French chalk, very hard and can be sharpened to quite a fine point
AJB Temple":2e0hkuzi said:They are chinagraph pencils. .......
MikeG.":23k1i2lp said:Trevanion":23k1i2lp said:......It's French chalk, very hard and can be sharpened to quite a fine point
I've got loads of that. No, it's a pencil I'm after. I've even seen it as a propelling pencil.
I got a couple of decent white pencils from Workshop Heaven a while back; excellent for marking on Bog Oak and other dark timbers - RobMikeG.":3tct4kdu said:Trevanion":3tct4kdu said:......It's French chalk, very hard and can be sharpened to quite a fine point
woodbloke66":p1fcmo1i said:2. Marking out tools - 150mm try square, marking knife, dovetail marking knife, a few marking gauges (min four) cutting gauge, mortice gauge, mitre set, sliding bevel gauge, 4H pencil, awl
quixoticgeek":3emop897 said:......Another beginner here. Please learn from my mistake. Don't buy cheap squares......
Make sure that your square is actually square. ..........
MikeG.":31zlcrtj said:This is wrong. A cheap square can be just as square as an expensive square. What you pay for with an expensive square is a higher chance that the first one you pick off the shelf will be square.
Yep, exactly. And an £8 combination square is just as good as an £80 one if it is square. It takes seconds to check in the shop.
quixoticgeek":s4m4gqtf said:.......Which is harder to do if you are buying mail order....
Or it's in some sort of packaging........
This was one of the big problems Mike with the old Axminster squares from a few years back. It was very 'hit n'missy' if the purchaser ever got hold of one that was true. Fortunately, all the ones I bought, inc the biggest 300mm square then on offer, were all spot on - RobMikeG.":1y4ecv0q said:Half dozen £8 to £15 squares and we found 2 that were spot on, 2 that were pretty damn good, and the rest were miles out.
