devonwoody
I eventually got out to the workshop at around 13.30 hours and the temp reached 10c with the help of a fan heater. Did a bit more jointing but wanted to do something more active, I therefore set up the table saw and cut all the dadoes dead centre 5 mm deep in all drawers. Used a back up on the second cut each time and avoided any tearout. Decided not to cut the positions on the frames today because I want a very accurate layout after my first box 6 months ago. I am going to make a cut on a frame and then put in a drawer to act as spacer and build up the positions in this fashion. Hoping this will avoid mark up errors. Even now I am still concerned about this step, wondering if I should build a sled to push timber past the unguarded blade. There will only be around 75mm between hand and blade.
Photograph of four drawers showing slide bars sitting snugly without any play.
