stuckinthemud
Cheers Tom, Wentwood was my first call, then Interesting Timbers but neither have anything suitable at the moment
The elm came from Witney Saw Mills from Witney on Wye, 5miles from Hay. Normally it is Which elm for welsh long bows because of the twisty grain it makes superbly tensioned limbs without all that yew messing about with heart and sap and the ring change needed in ash.
Have you seen this postI plan on making a replica of an 11th century crossbow. The original was 120cm long, 4cm wide and thick and used an elm or wych elm branch (probably) or sapling. I am having trouble sourcing any elm, can anyone suggest a supplier. I would rather not pay for a board as a stem or branch is best and on a board I only need the wany edge, although then it would need to be quarter sawn . Sorry if I seem a bit fussy, but thanks for looking, Andrew
Thanks Keith, much appreciated.
Suffolkboy, beef and deer sinew were commonly used, tendon from ankles and silverskin from the ribs, but most useful is the backstrap along the spine. In tendons, length is the most important factor
My preferred bowstring material is linen, though sinew does make an excellent string, its really really really difficult to come by in the UK as most butchers use prejointed cuts rather than butchering carcasses, so, any I get hold of I keep for backings
Umm, the trite reply is as much as I can get. I currently have a lightweight yew/sinew crossbow in-build which needs the equivalent of 6 leg tendons and 1 backstrap. Over the next 2 years, probably, I have started a horn composite I will probably sinew next summer that will need 5 to 10 times that, and somewhere along the way a heavy yew/sinew 16th century replica crossbow using a broadly similar amount and a Hungarian style horse archery bow...
Hi there I may be able to get hold of some from back straps from both red and fallow..... how do you want them storing etc? I would just vac pack and stick in freezer tilUmm, the trite reply is as much as I can get. I currently have a lightweight yew/sinew crossbow in-build which needs the equivalent of 6 leg tendons and 1 backstrap. Over the next 2 years, probably, I have started a horn composite I will probably sinew next summer that will need 5 to 10 times that, and somewhere along the way a heavy yew/sinew 16th century replica crossbow using a broadly similar amount and a Hungarian style horse archery bow...
