matt
Today I was lucky enough to have tracked down an EB PK200 and Scheppach 2010 both in the same showroom (side by side in fact). An ideal opportunity to sample both before buying... This was the first time that I'd seen the Scheppach in the flesh whereas I have seen the PK200 once before about a week ago.
I was already keen on the PK200 from my previous viewing but was drawn to the Scheppach by the extra few centimetres of cutting width (without side extensions) and the induction motor. Having now seen them both together I was disappointed by the Scheppach.
I thought I was summarise my observations because I know that these two saws are often compared by prospective purchasers:
In fairness to the Scheppach, it did not help that the rise and fall and tilt mechanisms also did not work on the display machine. The dust extraction port was also cracked, and the blade cover kept drooping down against the table surface because the clamp would not hold it. Also, the fine adjuster would not work. All in all, a poorly assembled display model.
I would be interested in any similar or contrasting opinions from current users. In particular, it would be useful to know how many PK200 users find the motor noise intolerably loud.
- Scheppach rip fence clamping mechanism seemed superior to the PK200 in that it uses quick release handles rather than a screw mechanishm. However, I could not fault the action of the PK200 clamp screw except I managed to break the plastic handle off to reveal a desperately inadequate but easily remedied design.
- The Scheppach's fine adjustment on the fence is a nice touch; however, the fence on the PK200 slides so smoothly by comparison to the Scheppach that it is equally easy to make very fine adjustments by simply tapping the lightly tensioned fence in to the precise location.
- I was keen on the fold-down side extension table on the Scheppach (in theory); however, having seen it, I think that Elektra Beckum have taken a far more thorough approach to extending the capacity of the saw by using extension rails.
- I still found myself drawn toward the queitness of the induction motor of the Scheppach until I thought some more and realised that the sound of wood being sawn by one of these machines tends to be the noisiest thing!
- Elektra Beckum have been clever in ensuring that all the contact points feel good. It does not always follow that real quality exists but I've not reason to doubt on this occasion.
- The mitre fence (whilst generally viewed as a bit of a waste of time) was far superior on the PK200. An all-metal arrangement with very clear measurements by contrast to the Sheppach's nasty plastic affair which, on the display machine, was broken. There was a screw thread to clamp the mitre but the leading edge was located (or not in this case) by a plastic lug.
